Two simple questions:
1) I need to install an outside lamp. I believe I need to connect a 2.5mm cable from the double plug socket to the FCU. I then need to change the fuse from 13A, but I'm not sure weather to go for a 3A or 5A since I don't know if my circuit or ring or radial? Is it then safe to check my connection at this stage which will show a red light on the FCU when switched on?
I need to do a bit of plastering and put a new skirting board before proceeding to the second stage, which will be to connect a cable from the FCU to the outside light. Does it matter if that cable is 1mm or 1.5mm?
2) I want to move a lighting switch to the other side of the door. I very difficult to know if the cable from the mains is 1mm or 1.5mm (with my glasses on and a ruler). Which size should I use from the existing switch to new one on the other side of the door, 1mm or 1.5mm, or doesn't it matter? Just want to make sure.
Many thanks!
Many thanks!
