Correction of poor finish
Discussion in 'Decorating and Painting' started by mellie_man, 30 Jun 2018.
  1. mellie_man
    mellie_man
    1 Mar 2008
    44
    Thanks Received:
    Bradford
    Country:
    hi
    I just painted exterior woodwork and decided to make the change to water based weather shield, as I was doing front door. Wrong week to do that. Temp is so high that paint was drying as I applied so finish is flat and brush marks visible.
    So my question is can I rubdown and put a second coat of gloss or does this not work with The new formula WB paints. Do I need to re undercoat as it dries so quickly.
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    75,031
    Thanks Received:
    4,350
    Crossgates, Europe
    Country:
    Cook Islands
    the water based gloss paints can be hard to sand as they form balls of paint.
    try it with minimal pressure and quite a fine paper.
    I presume that eventually they harden enough for it to get easier, but I don't know how long it takes.
    • Like Like x 1
  4. opps
    opps
    16 Jun 2006
    5,380
    Thanks Received:
    866
    London
    Country:
    Sanding it should be sufficient, however, most waterbased paints are a mare to sand. They tend to gum up the sand paper. You may be able to scrape the finish off using a plastic scraper (try to scratch it with your fingernail first to see how soft it is).
    When you recoat, add some Floetrol to the WB weathershield. It isn't cheap but well worth the money. It extends the wet edge and helps the paint flow without slowing the rate at which the paint cures.
    https://www.owatroldirect.co.uk/product/floetrol/
  5. ic1927
    ic1927
    20 Jul 2010
    481
    Thanks Received:
    143
    Mid Glamorgan
    Country:
    Leave it for a week to fully cure, then it should sand down fine, and use silicone carbide (wet and dry paper).
  6. opps
    opps
    16 Jun 2006
    5,380
    Thanks Received:
    866
    London
    Country:
    I have just finished painting a hallway. The last two times that it was painted the decorators use Farrow and Ball eggshell (which has been water based since about 2008) on the woodwork.
    The woodwork took between 5 and perhaps as much as 10 times longer to sand flat because of the waterbased finish. The last coat of paint was applied about 5 years ago, and thus was fully cured. It didn't gum up the paper on my Festool sanders but I suspect that it creates microballs of dust which reduce the cutting ability of the sand paper. It is almost as if the paper is bouncing over the surface rather than sanding it.
    I have thousands of pounds worth of sanders and dust extractors and am happy to spend whole days just sanding, however, I groan when faced with waterbased finishes.
  7. ic1927
    ic1927
    20 Jul 2010
    481
    Thanks Received:
    143
    Mid Glamorgan
    Country:
    I know what you mean, some of the water based finishes can be a nightmare, especially made worse when the last decorators haven't prepared the woodwork properly. Had a job a few years back where as soon as I started sanding the lot came off in sheets, what a mess. They had just dolloped it on straight over old oil gloss with zero prep and had used some b&q own brand water based satin ****e. I find wet sanding helps if the water based stuff is stable enough.
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
