I recently moved into a house of around 15yrs old that was fitted with a thermal storage system from new. Unfortunately the Gledhill Boilermate part of this is corroding a bit where the expansion tank and main unit join (its the base of the expansion tank thats leaking). I'll probably have to get a plumber to look at it but has anyone had similar problems and if so did it require replacement with a similar unit or did would I be better to change the system to a combi-boiler or other? It would also mean I could shift this to the attached garage.
Thanks,
Andy.
Thanks,
Andy.
