couple of plumbing questions for you...
6 Dec 2005
What is the best trap to use on a wash basin?
Which system has the most pipework?
Where are grommets most commonly used?
Sounds like you want others to do your homework for you. Sorry old son, but when you grow up you will have to stand on your own feet, so now's a good time to start. Get searchin'.
OK heres the crack lad...I've been trying to find the answers to these for the last week but no confirmation anywhere.
I reckon...
What is the best trap to use on a wash basin? Bottle Trap
Which system has the most pipework? Indirect
Where are grommets most commonly used? Electrical installations...when fitting into walls....
Don't suppose you can let me know if I am right then??
basin trap=bottle,s trap,p trap adjustable or fixed depends on basin,location visable,hidden no real correct answer
which sys has the most pipes? again you can do a one pipe sys as the name suggests only one pipe but it can serve many legs/branches again no correct answer all depends on requirements
where are grommets most commonly used?again they can be used on gas cws tanks,hot water tanks,most younger plumbers have never had the privilage of makeing hemp grommets.hope this helps
Hep waste valve.............a system with a lot of rads...........kids with glue ear :rolleyes: Who set the questions :?: If they are as written then they are ambiguous questions :eek: tell your tutor it`s (lead)dressers @dawn :LOL:
