Indeed not, as long as you were clear that's what you were doing, and not failing to grasp what "reasonably expected" meant.
ban-all-sheds";p="1230835 said:Even though that was clearly not the requirement.However, the concensus under the 16th was, at a minimum, all GF sockets and some sparks put all sockets on the RCD.
The regs are seldom clear.
I take your point that you are always quick to point out where others are advising exceeding the regs as if it were working to the regs.
As usual, it is all down to interpretation of the good book. The requirement was, as I remember,
"A socket outlet rated 32A or less which may reasonably be expected to supply portable equipment for use outdoors....."
They key bit being highlighted in bold.
A long history, I guess, of sparks going for overkill solutions because they are too scared to think for themselves.
It's not about being scared, it's about covering all bases. As RF says, it is a minimum, it can be exceeded.
Imagine a scenario where an unskilled user of an electrical installation (which could describe many householders) finds an RCD socket not working, or a downstairs socket damaged or inconvenient. They may well plug into the landing (or even a cooker control unit which may not have been RCD-protected) to run a lead outside.
If all bases are covered (ie the minimum requirements exceeded), then they would still be protected by RCD.
If nothing else it's good to see that you are consistent in having some cheap rubbish Protek MCB's to replace any failing cheap rubbish Contactum MCB's.
standard split load boards like yours are no longer allowed, ... although the common answer now seems to be dual split load boards (i.e. two RCDs).
Ran pretty short of ways on the original split CU so its got a baby brother now.
Mini trunking resized to ease cable entries, looks pretty industrial![]()
All ground floor rings and radials now on RCD side, only downside seems to be that when I button test any MK masterseal external rcd sockets I trip the CU rcd as well.
The 32Amp industrial socket now conforms to standards.
There is a folder not in pic with detailed data on all circuits.
View media item 12266
Talking to an NIC spark the other day (this'll generate a lot of flak....) and he says there's no harm in using two RCD's in line: if one fails, you have the other.
