Thanks all , I'll have a chat with him later, if you guys think it's alright I'm sure he will.
It's going on a 16a mcb that's rcd protected too.
Ok., he's coming off a single socket that's a radial from the 16a mcb,
If I understand correctly - no.will he ring it back to the socket ?
It's just a cable - larger than necessary.Is this good practice .
Don't do it then.There would be a lot of wood boxing to remove to take it back to the board and there's potential for asbestos which I don't think he wants to touch.
Well, extending the radial which is already there.So just a radial from the single socket then on 4mm.
How so? Domestic cables in non-domestic installations is ****e and improper.In which case your advice is irrelevant/inappropriate again
How will the cable know where it has been installed?Domestic cables in non-domestic installations
Who says, IET, NICEIC,ECA.....How so? Domestic cables in non-domestic installations is ****e and improper.
I have responded in a new thread, here: https://www.diynot.com/diy/threads/avoiding-spoiling-a-thread.636692/How so? Domestic cables in non-domestic installations is ****e and improper.
Cable conductors are more efficient if a single coreWhat do you mean, Blup?
Do you mean a solid core as opposed to stranded?Cable conductors are more efficient if a single core
Are they? In what way?Cable conductors are more efficient if a single core
YepDo you mean a solid core as opposed to stranded?
