The corner you're working into can be out of square (very common), you can cut from the wrong side and get a break-out (common DIY error), you can forget to make a final full depth cut on the correct side of the jig opening, cheap jigs don't always produce a tight joint at the curve, etc, etc. Biggest problems are probably levelling-up to start with, making sure you've got access to the joiners from below (when on solid-top corner carcasses) and taking-out the inevitable bow in the top when cramping-up - and ALL tops are bowed to a greater or lesser extent , it's just a matter of degree
How much am I likely to pay for someone in the trade to cut --- 4 angles to be cuts?
I had--- 1 angle cut three years ago. It was £50 then, but I cannot get hold of the man that cut it.
