H
HiZ
Hi, I have a cast iron soil pipe connected to my old pan which im about to remove and replace. I guess i need to use a multi-fit or whatever they are called which will convert. The problem is that the cast pipe has an inspection plate just near the flange to the pan and I boubt a multi-fit would get enough purchase.
I'll probably just cut the pipe back and fit a flexible plastic one so how do i cut the cast iron?
Rent a chain cutter from HSS?
cheers
cheers
