Cutting down a interior door
23 Nov 2007
Hi
I havnt got a circular saw but do have a electric planer. I need to remove around 10mm of the top and bottom of a timber door. I used the electric planer before and its very violent and creates lots of rough edges and splits the wood very easy (was roughly cutting down the old doors when new carpets went it) it was the cheapest one homebase had. Problem is I live in a small flat and there is no where inside really to use something that throws lots of saw dust everywhere.
Questions are, I have a new fine toothed hand saw, could this be used to trim the doors?
Also are there any metal braces/screws in a timber door? when i trimmed the hollow panel doors I hit a metal brace only after taking off a few mm!
28 Mar 2008
Sussex
you could use the electric planer taking small ammounts from each side thus reducing chip out.
or if your feeling fit use the handsaw,you may well hit any staples that are used to fix the ply/hardboard panells to the frame work of the door.
bear in mind that the frame work is only about an inch thick all round(if egg box type door).
14 Mar 2006
Kent
The plane only splits timber if use incorrectly, you should work in from both ends , never running off the edge/corner.The vertical ends [end grain] of the door frame need 3-4 passes more than the base .Set blade at 1mm or less and take your time.
23 Nov 2007
At least I know why it was splitting, I was running it from one end to the other!
Problem is, it makes such a mess, im my tiny flat :confused:
The doors im buying will be solid wood. If I wanted to go down the handsaw route and I right in thinking solid timber door dont have staples in the joins, just glued?
Thanks for your help!
14 Mar 2006
Kent
You should not hit any obstructions, better to take the 20mm off the bottom unless you have a warped frame.You should have a bag on the planer or you can fit vacuum. Why not do it outside?
