Cutting Porceline Tiles Around a Round Mosiac
21 Mar 2006
Staffordshire
I have a round mosiac as a centre piece for my kitchen, I need to cut arround it with an accurate and neat curved cut the diameter of the mosaic is 30cm, the tiles are 30cm x 30cm I was thinking take a curved cut out of 4 tiles... how could that be done accuratley??
Best way will be to take the four tiles to your nearest water jet cutters and have it done by them, probably worth having a quater circle cut out of 5 tiles so you have one to cover brakages.
http://www.waterjetcutting.co.uk/ceramic-floor-and-wall-tiles.htm
If they are soft ceramics with a softish bisc then a roto-zip or dremel with tile cutting bit and a circle jig will do it quite well.
Jason
The versatility of this technology has made it a production requirement in a number of industries. Since the technology was first developed in the 1950s, it has been applied to everything from ceramic cutting to cutting foam, rubber, composites, and glass. Water jet cutting systems’ precision accuracy has been used for cutting designs, fabricating custom automotive parts, slicing frozen pizzas before packaging, and even creating parts for aircraft fuselages.
water jet ceramic cutting
