Hi everyone. Some photos here :
I'm cutting back these tiled areas because I'm fitting laminate up to it and the threshold needs to be in line with the door, otherwise it won't look right.
I've got a mini angle grinder and multi cutter. But I'm not sure which to use ?
The grinder will kick up a lot of dust. The multi cutter will need a tile cutter bit, but will it work ?? Bit of advice appreciated here
P.s. I did not fit these tiles so I don't know what may lie underneath.
