If someone had just moved into a property which had been repossessed and the CU had been smashed of the wall, leaving a dangerous situation of exposed live cables, would it be notifiable work to replace the CU seems its damaged and dangerous?
But your not allowed to pull the main fuse either Best option is to call the DNO straight away and get them to come and make safe - if it is dangerous they will be there within an hour or 2.
Part P allows for mergency repairs to be carried out and then notified so you could repair this today and then notify the council on Monday. If you are chaning the CU then you should carry out all the tests and complete an EIC.
if all the devices are in good order then i don't belive its notifiable to put them in a new enclosure.
replacing the breakers even with the same values is at least according to the law (iirc certain official documents say that like for like is not notifiable but this is not backed up by the law itself).
If you are changing the protection arrangements in any way then it is certainly notifiable.
