Hi all, newbie poster but been lurking and reading loads since buying our 60’s build end of terrace that needs lots of love back in mid-June!
I’ll try to keep this short, but looking for some advice (will call in a pro if needed, of course):
2 weekends ago we ripped out the old kitchen to prepare for a new one being fitted end of Aug, incl preparing a new floor, sorting out the electrics and re-skimming the walls. Upon pulling out a base unit I noticed a slightly damp patch on the floor beneath, but it dried up literally overnight so assumed it was due to something being trapped under the base unit and not allowing airflow.
Fast forward to yesterday, we were just working on getting some of the old tile adhesive off the walls and we noticed the damp patch was back in the same spot. Bare in mind this has been uncovered for the last 2 weeks, we’ve not noticed it before and is in plain sight as right by the front door.
The waste pipe runs down this corner and is boxed in (typical of all houses on this street) so we removed the bottom panels to get a better look. The boxed in section was packed with old sponge and stuffing similar to what you’d get in a stuffed toy, and full of debris like newspaper strips/bits of wood/an old lipstick(?!) and just lots of dirt and build-up from goodness knows how many years. We cleared it all out and checked for a leak in the pipe by running the shower and sink taps, nothing showed up. It didn’t get any wetter.
Checked outside - there is a small patch of repointing that needs doing on the external corner. We cut away an overgrown bush to have a closer look and saw nothing on the outside that suggested any issues - the brickwork and earth was bone dry and seems to be below where the DPM would be.
Also to note, there’s no dampness on the internal walls around this floor patch, apart from a little bit that must have seeped up - no more than an inch or so. Nothing higher up, and nothing on the ceiling.
Could it be the waste pipe has a slow, undetectable leak around the seal where it goes into the ground? Or could it be the little bit of pointing that’s degraded?
As I said I am happy to get someone round to take a look, but conscious of “damp proof experts” selling silicone injections. Pics attached (and please ignore the old water damage on the green wall - this is from a burst filter tap pipe that has since been removed).
TIA, and apologies that it’s such a long post! Some pics attached, including outside.
Taken yesterday after clearing out the debris:
Outside:
This morning:
Outside:
This morning:
