The chimney stack in my lounge seems to have moisture appearing right at the top of the of it. It also happens occasionally in the kitchen at the same height.
The strange thing is is that it only happens when we turn the heating on. We can have a really heavy down pour for five/six hours straight with not one damp patch appearing. When the heating goes on the moisture seems to be sucked in. The exterior brickwork has all been painted white (although it was done long before we purchased the house, it was also done professionally).
I have read into common problems with Victorian houses and a common theme seems to be moisture being pulled in through the walls due to a lack of ventilation and too much heat. We keep many windows on half lock through the house and we also have the original wooden front door which is quite drafty so that keeps air moving through the house.
Both the lounge and the kitchen have chimneys, the kitchen chimney has been removed halfway down with kitchen units installed underneath with an inset gas hob. An extractor has been mounted into the chimney.
The lounge fireplace is currently bricked up with a square left for ventilation (although it was tiled over, which we have sinced removed). We're just in the process of taking the bricks out and reinstating a coal fire which will help with ventilation.
There is a bedroom above the lounge which has a boarded up fireplace, no signs of moisture on the chimney at all. No moisture problems upstairs at all on the chimneys.
Before I get the builders in I just want to see if anyone has experienced anything similar.
