From my experiences in a relatively old house, a key factor which can contribute to the passage of damp into an internal wall is a blocked/bridged cavity. This allows damp to be bridged in from the external leaf to the internal leaf, but is not rising damp. The surveyor comes along, places his unsuitable damp meter (designed for timber) on a piece of plasterwork and declares that the property has rising damp, and that the best method is to install a chemical dpc and hack off 3' of plaster all over the house (I am sure these surveyors hold shares in the chemical & plastering companies).
In our house parts of the cavity have been filled with bits of bricks etc etc from incompent window fitters knocking stuff inside the cavity and no amount of chemical injection would prevent moisture travelling though this rubble from the outside to the inside. This can be made worse by incompetent use of SDS drills during chemical injection with bits of brick being 'popped off' the back of the walls into the cavity.
Before I discovered this forum, I made the costly mistake of having a 'dpc' injected and months later, during a discussion over a pint with a local builder (i.e. a person who builds houses not just drills holes and put chemicals in them) was told that the injection technique is a complete waste of time (oh, and money too). I'd have been better off getting the cavity cleared out and putting new/more airbricks in (it's surprising how well air can keep things dry). He informed me that if he replaces a DPC then he removes a course of brickwork (in 3' increments), clears the cavity, puts a physical DPC in place, replaces the bricks and re-points. A far more thorough method in my opinion.
A question for dano1779 - if these injected dpc's are as good as the injection companies would have us believe, then why the hell do most firms only offer a 10 year guarantee?
