Danfoss BFP oil pumps
7 Feb 2008
Northumberland
I'm replacing my third BFP 21 L3 oil pump this month.....and each one is leaking from the pressure adjusting port (4mm allen key). :shock:
New 'o' rings don't seem to be available - is this correct? :? Seems a bit over the top to fit a new pump just because of this.
Comments?
John :)
Thanks for reminding me I had 1 last week but I nicked the screw and washer out of a stock item in van hoping I will order new one and replace it but I forgot to do it and now your telling me u can't get one :(
The bigger 'o' ring for the body casing is available (under the 4 allen screws), but its the smaller one over the pressure adjusting spindle thats giving me grief...often I can stop the leaks by turning the pressure adjustment screw to and fro but on the last few pumps the kerosene just pyssed out.
John :)
Have had the same on Riello pumps as well. What are the oil suppliers not telling us?
I can't work their pricing out.....Danfoss solenoid coil about £30. BFP filter about £15. makes the complete pump (£71 yesterday) pretty good value really as the solenoid and filter are included!
All I needed was one 'o' ring....cost around 0.02p.
The punter was delighted...the boiler (Trianco thing, Bentone burner) was sitting in a pool of kero and had done for a month. :shock: One drip every 20 sec and all he complained about was the pong.
John :)
I personally would not change a 2p O ring, how much could you charge the customer for that £30?? then a few days later the O ring lets go and oil damage occurs to the property - customer will hold you responsible so you inform your insurance Co who start asking questions about the origins of the 2p o ring etc ...and even if they agree to pay out it still leaves you with a £500 excess and if Vat reg you will be footing the Vat bill for the whole lot, I would prefer to fit a new pump parts and labour about £150+vat a Years gaurantee on the pump and the chance of trouble?...much reduced!! :wink:
