Danfoss tp5000si thermostat display problems
On the contrary, quite a lot of hard wired thermostats use batteries, especially ones that do not require a neutral wire.
So i’m quite confused now, as i pulled the thermostat off the wall and it was still on, but had a 4core power cable going to it also. So are the batteries just a back up? Also I didn’t see any low voltage cables so does this mean it’s a wireless unit? Where would i find the receiver?
No it doesn’t mean it’s wireless, as the wires are behind it - these are used to send (switch) the live to the zone valve(s). I don’t know why batteries are used in this instance, it might be to do with saving settings.
It's an SI control
Service Interval
Designed to stop working if the system is not regularly maintained.
Typically installed in rental properties, but also sold off at low prices because most people don't want a product that does that.
It's an SI control
Service Interval
Ah ok, my house is a new build so maybe got installed because it’s cheap?
So whats the solution? Get the boiler serviced and then it will be ok?
My Danfoss tp5000si display has all of a sudden stopped displaying the time and intstead shows only 2 dots flashing where the time normally is and also the temperature, which when i first looked was down at 5c
Read what I have posted. Nothing wrong with your thermostat.
Will be a retrofit. Would have been a normal thermostat replaced by present unit carrying out time and temperature function. Programmer either bypassed or set to ON to defer control to TP5000. Done that many times
Brilliant thanks, so whats the solution please?
Press the up and down arrow together. Or look at the manual on how to remove the programmer from frost setting
