    Dismiss Notice
DD GR10q 4 pin LED
Discussion in 'Electrics UK' started by john4703, 21 Mar 2021.
  1. john4703
    john4703
    29 Sep 2009
    477
    Thanks Received:
    28
    Glasgow
    Country:
    I want to replace some fluorescent D shaped tubes with LED.
    They are in the entrance foyer and the toilets of a church. I've fitted PIR sensors as people kept leaving the lights on. I'd like LEDs as they use less electricity and start virtually instantly. I know that I'd need to change the starter.
    Does anyone know where I can get replacement tubes that are LEDs?
    I don't want to change the whole fitting as that would be expensive. I'd rather replace tubes as the existing ones fail.
  2. Sponsored Links
  3. RF Lighting
    RF Lighting
    31 Mar 2006
    19,993
    Thanks Received:
    1,354
    Leeds
    Country:
    First question - do you know if these fittings have an electronic or a wire wound ballast? do they all have a replaceable switch starter? Also are any of these fittings combined emergency lights?
  4. john4703
    john4703
    29 Sep 2009
    477
    Thanks Received:
    28
    Glasgow
    Country:
    Thanks RF for replying.
    I know none of them are emergency lights.
    They have starters that look like the starters in a "normal" fluorescent batten fitting.
    They are roughly 20 years old if that gives any idea of what they will be.
  5. flameport
    flameport
    10 Mar 2007
    9,492
    Thanks Received:
    1,865
    Poole, Dorset
    Country:
  6. RF Lighting
    RF Lighting
    31 Mar 2006
    19,993
    Thanks Received:
    1,354
    Leeds
    Country:
    I forgot to ask - are your existing lamps 16W, 28W or 38W?
  7. john4703
    john4703
    29 Sep 2009
    477
    Thanks Received:
    28
    Glasgow
    Country:
    28W
  8. john4703
    john4703
    29 Sep 2009
    477
    Thanks Received:
    28
    Glasgow
    Country:
    Thanks.
    How did I miss that? I use CEF so should have looked at them.
    The advantage of changing the "tubes" is that if I do a few at a time they will still look the same. If I change the whole fitting I'd need to do them all to keep them looking reasonably uniform. possibly a better option (I'll ask the treasurer)
  9. Sponsored Links
Share This Page
