As ever, everything in my house is a big project and it is all dive-in-at-the-deep-end. I'm just dipping my toes at the moment, or something. Anyway...
I have 4.8m by 4.8m of a slope to deck. I am going to sink posts into the ground with concrete and have worked/drawn out a plan.
I would like some help, please:
1. Should the posts be 75mm x 75mm or 100mm x 100mm? What should the size of the corresponding hole be?
2. Should there be a slope on the decking, just to allow rainwater to run off? What should this slope be?
3. I thought I could lay the boards right on top of the joists (because that is how floorboards are laid and I have seen pictures of decking like this), but then saw this picture:
It has bearers across the joists then the boards lay on top of these bearers in the same direction as the joists. Is this just because of joist layout necessity and/or board layout choice i.e aesthetics?
4. Wood lengths come in 2.4m or at least this is managable. I need two of these end-to-end both ways. How do I join them/how do I join them to the posts? Do I put an extra thick post in where they will join and have each joist going half way along the post, like this:
Or brace them together at some point inbetween two normal-sized posts?
Apologies if these seem daft and thanks for any help!
? Or brace them together at some point inbetween two normal-sized posts?
