- Joined
- 26 Aug 2016
- Messages
- 6,833
- Reaction score
- 1,010
- Country
I noticed our builder threw the old gas pipe in the skip from the hob. Anyway I fetched it back out, and capped both ends then threw it back in again
so what are you achieving think about it my dear chapI noticed our builder threw the old gas pipe in the skip from the hob. Anyway I fetched it back out, and capped both ends then threw it back in again
The only thing I'm achieving is making the point that nothing's as clear cut as it seems on paper. Makes for a good debate though!so what are you achieving think about my dear chap
Andy Plumb:When you r client phoned you to complain of gs smell, what did you do?
a) Visit to recheck
b) Tell them it must be okay
c) Advise to phone Nat Grid (or whatever)
d) None of the above
e) Tell them to burn it off.
That comments made my fooking weekI noticed our builder threw the old gas pipe in the skip from the hob. Anyway I fetched it back out, and capped both ends then threw it back in again
Until a pipe has been used for conveying gas then it is just a pipe and does not need to be capped ( although wise to do so to stop mice etc. )
Once a pipe has been used for gas then it is has become a gas pipe and both ends need to be capped.
Pretty simple really.
If you are really keen you could also put a test nipple at one end.
Last question could be does it have to be an RGI who is capping the no longer used gas pipe. I would say that it does!
Doesn't need to be connected to a gas meter/supply, if it was connect to say the boiler and not connected to the meter is it a gas pipe?Perhaps so on a large steel pipe painted in yellow ochre.
But a 22mm copper pipe bought from B&Q is not a gas pipe until its installed for that purpose and connected to a gas supply.
I'd it isn't a gas pipe until it carries gas, then any twonk could install it.
