So, heres my little story bit. I was soldering on a stop end on a 22mm pipe and forgot to hold it steady with something, so it starts sliding, not having anything to hand to stop it moving I thought I'd finish soldering it and see what happens. It slid very very nearly off the pipe maybe a 1-2mm to spare then stuck there, so I finished soldering it, and had a trail of silver pipe about the length of a stop end and a stop end sitting which appeared soldered. Gave it a couple of tugs, seemed stuck firm, Curious if it would stay there or not, I put a bucket by it and turned on the water. Doesn't move.
Anyways, then I think you can't leave it like that and try to desolder it. Now there is water in the pipes, it's really not going anywhere...
There is no easy way to drain this pipe and like a prat I cut it as short as I possibly could down to the very last mm (literally) when putting the stop end on. Now I can cut the pipe and desolder it that way but it will mean cutting a perfectly good section of pipe and adding in an unnecessary join.
Can it be done, desolder with water in pipes?
