Difference between Phillips, Possi drive, cross head?
30 Jan 2008
Essex
As above really, I always thought they were the same, until reading on here, so can someone please explain the differences.
Paul
Philips and cross head are the same - as simple cross.
Pozi is similar, but has a slight flat end. But the easiest way to tell if a screw is Philips or Pozi is that Pozi has small lines between the cross. Pozi is generally more widely used.
You'll need to use the correct screwdriver for either...otherwise you chew it up.
This shows the difference
Thank you very much.
May explain why I chew up so many screws/bits
just to add in woodwork 90% off the time you need a pozi 2 bit also now known by "pro " prefix
in metric 3 3.5 4 4.5 and 5 take pozi 2 and imperial 6 7 8 10s
with metric sixes can be both pozi 2 or 3 and imperial 12 are pozi3
also in imperial no4 s use a pozi 1 but can somtimes work better with philips [ph1]
basicly the screw should sit on the bit without much or any sidways movement you should also be able to carry the screw on the bit to the wood
That helps too thanks, looks like im gunna get myself a few new bits
The screws are as important as the bits - el cheapo trade packs from DIY sheds can be a pain as the driver recess is not as accurately cut as on 'proper' screws - If you're just installing loft flooring or similar then by all means save your money but for anything where you need to be sure the screw goes in straight and with minimum fuss then it's bast to avoid.
Also with cheapy screws you will normally need to drill a pilot hole first - I've got a load of the screwfix Turbogold screws and I very rarely have to drill a pilot with these.
Vis a vis brands you can't go wrong with Spax but anything you pick up from somewhere like Screwfix should be OK.
I'd get decent bits if I were you, the cheap ones are awfully soft...I'd rather have 2 or 3 top quality ones than a boxful of cheapies.
Talking of nice bits, I have a 90mm PZ2 Wera bit that I use on an impact drill and it has outlasted 5-6 regular Dewalt PZ2 bits! And its still going strong.
I've got a Wera Diamond PZ2 bit that's excellent but I rarely use it as I have a bosch PZ2 ACR bit that is still going strong despite a good few years of abuse!
In the "cross head" style there are also Chinese and Japanese variants. They tend to be more pointed then Philips. The sides of the cross are also thinner so they rattle about in the posidrive cross. FWIW Philip headed screws were invented in the States so they could assemble radio sets with air powered tools. I don't think that in WW2 they worried too much about taking them out again!
Frank
Hi, if you are using a drill when doing up screws, always set the speed to low, you will get better control by doing this and also not chew the bits up so often.
