Hi
Is it true that energy savings bulbs don't go with dimmer switches?
I am wondering whether it is worth cconverting the dimmer switch into a normal one - idea being to save energy convert to ES bulbs if the answer to above is Yes. So, can you pls advise if less electricity is consumed if the dimmer is at minimum ie to put it another way, is the same amount of electricity consumed whatever the light intensity the dimmer setting is?
Thanks.
Thanks.
