disconected gas cooker
  • Thread starter Thread starter dibby90
  • Start date Start date
That is quite so but that testing idea was thought up for normally on boiler pilot lights.
I would say that it is very important on a hob that they do not stay on without a flame.
But I am still suspicious of the OP's assessment that all four are failed to on!
Are you suggesting a hob to be "more important" than an appliance that utilises a combustion chamber?
Much more important in many ways!
A gas leaking cooker will fill the kitchen with gas!
Gas from a leaking pilot light in a room sealed boiler will safely disperse through the flue.
I think you may have missed the cut off times from my previous post?
Why do you think water heaters/boilers etc utilise a shorter cut of time than that of a cooker/fire/DFE?
Why do you think an oven has a shorter cut of time than that of a hob/hot plate?
Are you going to vanish from this thread as usual?
I dont get how lighting an appliance with a lighter is classed as safe, just doesn't sit right with me. I've always said its unsafe but thanks for letting me know different, been gas safe 2 years now but still need abit of guidance and experience obviously
Take it from me Dibby it's a minefield at times.
We have to walk on a very fine line at times.
Dibby, your client doesn't need to use a lighter, a proper taper or spill is better. Or a blowlamp. Ignition on cookers was state of the art when I started. And not too long before, there were no FFD's. On Xmas Eve, with the Gas Board, our emergency repair method for failed FFDs, on the oven, was too rip out the guts, and reassemble and seal the case. It was considered better than depriving the punters family of their Turkey the next day.
But then, the Turkey was always dried out crap because it went in the oven, on low, the night before. :)
There have been some lighting devices on many earlier cookers.
There was the little gas torch on a flexible tube used to convey the flame from a pilot light to each burner.
Then the little tubes taking a little gas from each burner to a central pilot flame in the middle of the hob.
Then the little glow ignitor with a 1.5v battery at the base of the cooker. That one was cleverly used as the basis of the flame detector on the Potty Lynx boiler. Clever alternative thinking whoever thought of that. How long will it take Bernard to google how that worked?
My parents had one of them when I was growing up. I can vividly remember having HOT seared into my fingertips when I touched it to see if it was really hot :LOL::LOL::LOL:
