Disconnecting an External Rotary Switch - Advice Needed
5 Apr 2013
Hampshire
Hi all
I'm getting rid of a hot tub and the only connection on it is a electrical lead to a rotary switch.
To disconnect this, is it just a case of switching the electric off, taking it apart, and then disconnecting. Or is there more to it than that?
No electrical knowledge here - I can just about wire a plug!
Thanks!
Yes there is more.
The cable bringing power to the rotary switch will have to be made safe if the rotary switch is removed. That cable end cannot just be left with the other end connected to the supply. It needs to be disconnected from the supply.
Even if the rotary switch is left in place the removal of the cable to the hot tub will probably leave a hole in the casing that can be a hazard, fingers poking in, water getting in, metal object poked in by inquisitive children etc etc,
You need to identify where the hot tub is powered from. Probably a separate fuse/MCB connection in your consumer unit. It is important to completely disconnect all cores of that cable at that place.
This may mean getting your hands in the guts of a consumer unit where there are dangerous voltages.
Better to get an electrician in, if you don't have a clue.
An alternative option (subject to the cable size and breaker rating being appropriate and the location suitable) may be to replace the rotary isolator with a socket.
Thanks for all your replies!
Does anyone think I could isolate the switch at the main breaker until I can get an electrician to look at it, as a temporary solution?
Of course but it will depend on how the cable is terminated at the supply end. It must be switched off and locked off do there's no chance that somebody will turn it on again.
Post a picture of what is at the supply end. It may be a double pole isolator, or RCD.
