Distributed Sky (problem with Freeview Signal)
1 Apr 2012
Cambridgeshire
Hello.
I currently have Sky HD distributed throughout my house via coax. The signal has always been great (with CRT TV's) - but since we have upgraded the 'edge' televisions to Freeview, the signal really has deteriorated.
I have isolated the problem by removing the connection to the Freeview ariel, all the Televisions tuned into the frequency I have set on the Sky RT Output (C50) were all far far better.
Knowledgeable people…. is there a way to isolate the digital signal to improve the analogue signal used for Sky? I have tried changing the RT Output channel without noticeable change.
Any idea's?
Thanks, Jay
Hello.
I don't think that's possible. You have to use HDMI cable or do it via CAT5/6 cable, otherwise you get SD.
I don't know what an 'edge' television is.
I have isolated the problem by removing the connection to the Freeview ariel, {aerial.} All the Televisions tuned into the frequency I have set on the Sky RT Output (C50) were all far far better.
You need to locate a clear UHF channel and set the Digibox RF output to that. If there isn't a clear one, then you'll have to fit a passband filter to clear space by removing some unwanted channels.
I was perhaps was not clear in my description, however you have answered my question..... the above has worked to a certain extent (changing the channel) - I just need to find a channel with enough clear space to stop affecting the image.
I have tried 50/ 68 but can't seem to have a listing for Sandy Heath - trial and error looks like way forward, and in not, research on a passband filter.
Thanks for your help.
See http://www.wolfbane.com/cgi-bin/tvd.exe?DX=L&HT=10&OS=LU7
Sandy Heath uses 21, 24, 27, 31, 48, 52
C.P. uses 23, 25, 26, 28, 30
Oxford uses 53, 55, 57, 59, 60
Hemel uses 41, 44, 47, 50, 55, 59
There's a possibility of interference from all of them and nobody makes a suitable filter. So, if your Sandy Heath signal is strong, I'd recommend fitting a variable attenuator to the Sky aerial input and see if you can wind up the attenuation without affecting Freeview reception.
