I've removed my (recently died) wired alarm system and replaced with a Ring alarm.
The old alarm panel was powered from a fused spur, fed from a dedicated MCB on the consumer unit. I'd like to put the Ring alarm base station on the wall in this location, but also utilise the existing alarm cabling to provide power to the outdoor siren and a Ring doorbell (no existing wired doorbell).
Looking for ideas for the best/tidiest way to achieve this
Ring Base Station has a plug-in adapter.
Ring Outdoor Siren needs 9-28VDC, 12-40W.
Ring Video Doorbell Wired is compatible with most standard 8-24VAC doorbell transformers.
Both are compatible with the Ring Plug-In Adapter (24VDC, 0.5A, 12.0W) but this is currently out of stock for 2-4 months. Could get an equivalent spec alternative elsewhere (Ring state to only use Ring DC power supplies, as these have additional protection designed for Ring Video Doorbells - but not sure how critical this is!)
One option seems to be change the fused spur to a socket, plug in an extension lead, then use plug-in adapters and join them onto the relevant alarm cables for the siren & doorbell, and plug in the base station. This would all then need boxing in / hiding with a cabinet
Wondering if there's a tidier/more professional way of doing this, ideally something that would mount over where the existing alarm cables exit the wall (or components I could tuck into the old alarm enclosure).
