Indeed.been told?
Who knows. Why are you asking me?And is that true?
Indeed.been told?
Table 41.1.You tell me![]()
As I said, that relates to the BS7671 requirements for disconnection times.Table 41.1.
The bus bar has about 4 or 5 flats off each bar. Not seen the fuses for each phase. From main fuse holder to the flat's CU and onwards is all fine being suitable for 100A.Yes, but as I've asked ... (a) what is upstream of that fuse cabinet (i.e. what is the rating of the DNO fuse for each phase? ... and (b) is there just one fuse (presumably 63A, not 62A), for your flat, bolted to the busbar for the phase of interest - or does that busbar also supply any other flats?
Are you saying that the bar which supplies the flat we're talking about also has 3 or 4 other (63A, 62A or 60A) fuses connected to it, supplying other flats (in other words, a total of 12-15 such fuses in the box)?The bus bar has about 4 or 5 flats off each bar. Not seen the fuses for each phase.
Yep. I am not in the place for around a week.Are you saying that the bar which supplies the flat we're talking about also has 3 or 4 other (63A, 62A or 60A) fuses connected to it, supplying other flats (in other words, a total of 12-15 such fuses in the box)?
Fair enough, but it does sound as if you are probably well out of your depth.Yep. I am not in the place for around a week.
Thermal overload is approx. twice the rated current of an mcb. This is all by the way of the prime point.
I also have to wonder if 'your' flat is appreciably different from all of the other dozen or so. Whilst the others may all have gas heating, it would not surprise me if at least some of them had electric showers - which would probably make them similar in terms of 'maximum electricity demand' to yours with UFH.
From someone who was involved in installing 3 phase generators, I am far from out of my depth. The fuse cabinet is not the issue.Fair enough, but it does sound as if you are probably well out of your depth.
Well, one hopes that means that you wouldn't be out of your depth if we were discussing the installation of 3-phase generators - although I don't really see that installation of generators has much to do with what you have been discussing here.From someone who was involved in installing 3 phase generators, I am far from out of my depth.
I don't think that any of us have said that it is, but your entire problem seems to relate to the fact that the cabinet bears a "63A only" sticker, doesn't it?The fuse cabinet is not the issue.
That is not a problem as it cannot be solved. It stays at 63A. The problem is inside the flat. The problem boils down to a calculation, which as a few have mentioned, may be better substituted by a common sense.Well, one hopes that means that you wouldn't be out of your depth if we were discussing the installation of 3-phase generators - although I don't really see that installation of generators has much to do with what you have been discussing here.
That seems a rather odd thing to say - since, were it not for that "63A" sticker, you would presumably have had no reason to start this discussion?That is not a problem ....
I would be one of those 'few' - and, as I have said, and for what it's worth, my view of the common sense is that you really should not have any concerns. However, as you do seem to have concerns, it seems that you probably need someone with sufficient knowledge and understanding to advise, hopefully reassure, you.The problem is inside the flat. The problem boils down to a calculation, which as a few have mentioned, may be better substituted by a common sense.
It's all a bit confusing, but the impression I get is that most of what we have told about is hypothetical, such that there is not currently very much in situ to actually measure - the OP seems to still be considering thermal store wet UFH & DHW as a possible option and is still debating the types of cooking/laundry appliances. However, maybe I have misunderstood.Why not just stick a clamp meter on the flats incoming supply and see what actualy happens if you simulate a realistic maximum demand situation? .... Then you can see if you do actualy have a problem or if you can stop worrying about it.
