All there is to know can be written on the back of a postage stamp
Not with your eyesight mate
Take the crash course and you too can become a plumbing and heating engineer , just imagine the money to be made repairing boilers once you become gas safe.
For sure.....allow another week to take you through commercial...
If water gets in the diverter motor it could damage the pcb.
If you take it on you will flood the boiler.
Even if u drain the boiler till the water stops, when you remove the valve a load more water will come out.
Just get it fixed.
I would charge maybe a little less but defo wouldn't take 2 hours
My view on diverter valve replacement....
Isolate main supply and loosen off the three screws that hold diverter valve to chassis plate.......fitting new valve reverse procedure.....
Have some towels to hand....you're gonna need em lol...
They are a doddle but I always spray the back screws with a little penetrating oil and use a flat blade to loosen rather than mangle them with a Phillips as they are so soft. Worth getting an absorbant pad (5l) underneath.
