DO I NEED 10 AAVs
The sink in question was in a botched job which I had been asked to advise on.
There were no clips supplied and I had asked what type of clips were usually supplied now.
Kitchen fitting is not the same as heating!
The kitchen fitter had put the kitchen together in a way that made it impossible to hold the sink down.
Tony
Can you elaborate on this as cannot visualise what you mean. Never known a situation where the sink unit cannot be fixed in the countertop
This is nothing to do with the topic being discussed by the OP.
The "kitchen fitter" had put a horizontal bar immediately under the work top extending about 65mm back into the cut out so preventing any normal sink fixings holding down the front edge of the sink.
Tony
agile then just tell joiner to come back do his job properly
and stil see no reason for that many aavs unless pelchy near by
The son and daughter of the owner had called this "kitchen fitter" who was Dutch but lived in Ireland.
I agreed to do the plumbing but had expected the sink to have been fitted into the worktop.
By the time I got there he was out of the country.
It was worse than that. When I first went they had parts missing from the mixer tap so I had to make a second visit.
Tony
FYI said battern is fitted too all kitchen base cabinets. Not something the kitchen fitter would decide to fit but designed so by the makers.
Easy fixed, don't see the problem.
Just checked the sink post he actually asked if it was ok to fit it using double sided tape. :shock: :roll: And this man fits heating . Does double sided tape work on rad brackets Agile ?
Most sinks say silicone can be used to secure if clips cannot be used.
Sinks seems along way from AAVs though ha ha
