I have enjoyed reading your forums on benefits of pressurised water for washing (Megaflows etc) - summarised as no tanks in loft,no need for shower pumps,more hot water for family of 5 to use.
Great ! so quite keen to commission a system as we want to convert a loft and add an extension which includes 2 bathrooms BUT our mains pressure inside is 2bar 13l /min. All the advice seems be be flow rate is key but water companies do not guarantee more than 1 bar 9 litres a minute. And yet these systems 'require' 20l/minute 2 bar.
How can I or other people go for a pressurised system when it will be subject to the vagaries of water pressure from outside home and even expensive ( £600-£800) new pipes from external stopcock can only pass on slightly improved flow rates ? And the systems are more expensive.
Or do these systems actually often work OK at lower flow rates. How come they are popular?
Both the water company technician and water supply pipe contractor were not convinced on pressurised systems (even tho the pipe contractor was doing himself out of a job). Our plumber is a bit nervous of the water supply although at customer insistence he has installed one on the same road which occupants seem to be happy with.
Our alternative is upgrade of what we have (keep cold water tank in loft) plus pumps for showers and probably electric shower and electric hot water hand washer unit in loft.
Trying to make a decision so any advice welcome.
