Why do new gas boilers have a vent/drain in a position right over the top of PCB?
Should there be a leak from it, first damage would be a 300 quid PCB!
Might just be Viessmann.
20 years ago my boiler had constant relay failures for the sake of a little suppression cap/resistor.
What I'm getting at is that there has always been lack of foresight when designing some stuff.
Boilers designed by people who do not work on them there lies the problem
The problem with wall mounted gas boilers is that the controls have to be accessible, so this means they are fitted at the bottom of the boiler and thus under the water works. Floor standing boilers are able to have the electronics above the waterworks, except for certain oil combi boiler manufacturers who persist positioning two circulating pumps beneath the 4 DHW heat exchanger connections which invariably leak after a couple of years.
