OK a bit of a generalisation, using the likes of Wiser, there is no real reason to have a wall thermostat, the TRV can do it all.I think I have said often enough that I don't think that's correct.
Well, one or the other. Or none of those.There is no reason why one should not have a wall thermostat in every room
Of course, but a fairly standard home with similar use is by far the most common. They'll likely have different heat loss characteristics, maybe a shower or bath difference, including how many, Maybe more or less rooms, but all in all it is still a pretty standard heating/hot water requirement. And yes, there are outliers that need a different approach, but that isn't the norm.We should design the system to suit the home and occupants, the idea of one design suits all, is clearly berrying ones head in the sand.
I'm beginning to think the OP is trolling. Anybody of moderate intelligence could understand what we've been saying.Yes, because the hall is cold. The other rooms won't heat up if the TRVs are satisfied. Only the hall will heat back up.
It's worth heating all rooms within the thermal envelope of your house since the insulation between them will be minimal compared with that of the main shell of the house.But i dont need the hall heated. I just wanted to find out the reasoning behind the hall been the reccomended place to put it
Yes, should work well, as it does not turn on/off, but up/down, if my boiler was opentherm enabled I would also use open them. My thermostats have the option but not the boiler.I have opentherm and weather compensation fitted, turn it on in the morning at around 20, adjust during the day as required, then turn it off before going to bed.
Works for us.
It turns off when the room stat temp is reached.Yes, should work well, as it does not turn on/off, but up/down, if my boiler was opentherm enabled I would also use open them. My thermostats have the option but not the boiler.
May be, although really is should turn it up or down, not on/off, but if the boiler will not go any lower, it will switch off, but with OpenTherm when it turns back on, it will be at lowest output, where with on/off thermostat it turns back on at highest output.It turns off when the room stat temp is reached.
When it reaches the set temperature it goes off, then comes back on when it drops enough. What do you mean it shouldn't turn off but turn down?May be, although really is should turn it up or down, not on/off
But weren't you the OP?I'm beginning to think the OP is trolling. Anybody of moderate intelligence could understand what we've been saying.
