Does Veritas R8 allow GSM or Telephone Unit
23 Jul 2010
Hi friends
I want your opinion on this issue.
I'm wondering to install an allarm on my house and i found with a nice price the veritas R8 system.
I need to know if this equipment allow incorporate an unit of GSM or telephone.
Thanks in advance :wink:
No. You could connect any speech / sms dialler to it, but it doesn't allow onboard comms.
You'd need something like the texecom premier for that.
I guys ...
I have acquired one system Veritas R8 that i've already installed in my home.
However i got one problem that i thank for help. All of my 4 zones are in instantanious alarm and i need to put them with delay (all of them).
I will be thankfull if some could indicate me the steps i need to do to program the alarm device in the terms i've refered.
thanks
You need to go into engineer mode and set the zones for either entry exit (which starts the entry tone) or walk through (allows you to pass through after the entry exit zone has activated)
each zone needs to be programmed
11 for Z1, 12 for Z2, 13 for Z3 and 14 for Z4
select options 06 for entry exit or option 02 for walk through.
Well, if I understood I'll need to do this steps:
engineer code / 11 / 1 / Prog / 06 / Prog
/ 12 / 2 / Prog / 06 / Prog
/ 13 / 3 / Prog / 06 / Prog
/ 14 / 4 / Prog / 06 / Prog
Is that so ? Or simply this
Thanks in advance
Hi again
Thanks to those who helped me... sincerely it was easy and after a new read to the manual everything became clear.
:lol:
