Double Dimmer Switch Lose Wire
6 Jul 2020
We have a double dimmer switch in our lounge and whilst having some decorating done one of the wires has come out and I can’t work out where to put it back.
See picture below.
The 2 sets of terminals are labelled with L1, L2 and a squiggly line with an arrow through it (let’s call that S to save my typing).
There is a brown wire connecting the L1 terminals on both switches.
There is a yellow wire in S on one switch.
There is a red wire in the S on the other switch.
And there is a red wire that’s come out of somewhere and needs to be re-attached.
There’s then a blue and black wire connected together in a terminal block, and 2earth wires connected together to the side of the box.
It can’t be that hard, but I don’t want get get it wrong.
Either of the L1's
Make sure the power is turned off at the consumer unit[fuse box] before you go any further.
Also see them round things on the back of the switch they are the new screw covers to fit on your switch
@SUNRAY - Thank you so much. That worked. We have two working dimmer again and I have one happy girlfriend!
In with the brown link.
Is the loose red the same cable as the black wire?
