I'm installing 5 x 50w mains halogen downlights in my kitchen, I'm not an electrician so just want to check this is totally safe.
I bought some 1.5 Twin & earth cable but as the light housings swivel 360 degrees with no stop - I'm reluctant to use this as it doesnt bend much and I guess might become loose at some point. My local electrical factor has sold me some .75mm 3 core flex - will this be adequate?
I presume I can just connect the fittings by looping cable from one fitting to the next. Also - there is no earth connection on the (metal) fittings - I presume there is therefore no need to earth them (there is an earth on the existing supply).
Finally... they are connected to a dimmer rated at 400w - have hooked it up and seems to work ok - but have heard the dimmer needs to be rated 2x the fittings if they are mains halogen?
Thanks!
Thanks!
