downlighters in sloping ceiling
im using tri iso thermal quilt (1" thick) on the underside of the rafter
counterbatten along that
plasterboard on the batten
does this make a differnece to your answer
As you can tell im keen to use downlighters
or shall we say SHE is keen .lol
I've just done an extension with sloping ceilings and the same sort of clearance.
The solution?
Surface spots :wink:
thanks nozspark
just posting this in case u missed my last reply (ref: the insulation im using) as me and RF posted at the same time
thanks for the pic rf
just a quick question...
where is the best place to buy firehood from?
(and before you all ask, yes there is flat above me, so I need them) :lol:
If you are using tri iso you should keep downlights a minium 200mm gap
as it is combustible.
It is about a million times easier to use fire rated downlights, rather than trying to fit firehoods to normal DLs
I might just do that.
The problem I brought a load of downlighter already, then realised they had no firehood/protection. :oops:
