DPM On Hardcore
4 Jan 2006
Devon
Hi;
I am laying some hardcore in advance of concreting a garden workshop floor. Do I need to put anything on top of the hardcore before laying a DPM? It looks as though it may get punctured / torn on the hardcore edges?
Skavenger, good evening.
Suggest you consider a layer of sand between DPM and hardcore.
But? the sand can wash out if the edges are not closed of with a brick perimeter wall or similar. mixing cement will reduce leaching of the sand.
The most commonly used material is a so called "Lean mix Concrete" a "Weak Concrete mix" generally 50.mm thick, generally less than 7.5 Kn. Can you adjust the heights to accommodate the Lean mix?
Ken.
Ken.
I could 125mm hardcore, 50mm weak concrete and 75mm concrete?
What would be a weak mix 10:1 (Ballast / Cement)
But sand would be easier, the hardcore comes to the top of my wall footings so the sand would be encased by four walls. So I just even out the hardcore with sand?
Sharp sand or builders sand?
