As my house continues to give up its problems here is the next one! I pulled up the drain covers while cleaning out the soil filled gulleys and found the kitchen sink waste pipe broken off at the lions mouth (see the pictures - I have cleaned the grid too now!)
http://img843.imageshack.us/img843/4470/20120909114358.jpg
http://img812.imageshack.us/img812/6546/20120909114342.jpg
http://img684.imageshack.us/img684/8394/20120909114320.jpg
When the kitchen tap was on, and presumably washing machine and dishwasher too, the flow out of this broken white pipe causes quite a lot of water to fall against the wall and that nice big hole into what looks like the foundation of the kitchen? I suspect this is what is causing the dampness in the kitchen?? As a first step as I didn't have more time I have lined the back of the drain against the wall with some roofing felt tucked right up behind the broken pipe to try and keep the water away from the hole.
So two things - should it be quite easy to replace the pipe coming through the wall? I hope it will just pull out from the kitchen side? Getting behind the units in the kitchen to do that might not be straightforward though. I think the black drainpipe should extend a lot lower too so it is nearer the grid?
What should I do about the drain outside and the hole that shows the concrete (?) inside? Can this hole be covered with a cement mix or something, or does it need more serious attention?
