drayton rts problems
17 Oct 2009
Kent
hi
need some advice on replacing ny room thermostat
i changed the old one for a drayton rts 1 all wired up and only the hot water works, no c/h, thermostat clicks ive tried to wire it alll ways and blown 2 fuses in c/h switch box i need some advice before i call an electrician wire colours are brown,blue and green and yellow.
chris
N - Neutral
L - Live call from programmer
3 - Call for heat to mot valve.
i would say your
blue is neutral
brown is live
g/y is sw/l
check with a multi meter.
thanks for the advice it is wired that way now and seems to work.
radiators are warmong up.
just confusing why when i first did it with wiring like this pump and boiler didnt fire up,when hot water was demanded it fired up!!!
i then selected 24hr on timer for c/h will check c/h in morn on its own to see if it works.
once again thanks
hope so
ill see tomorrow
its gone off now when i thought it would carry on
seems it turned off when the hot water went off
yes programmed to come on up to ten pm
set thermostat to 25 degs
it went off coincidentally when it had heated a tank of water.
never had a prob before
only changed thermstat because it would only turn on above 30 degs
im a bit confused now dont know whats wrong withit
could you tell me how to fix back my old thermostat at least it worked
i didnt take note where the wires came off but no 1,3 and 2 screws are loose
its a honey well thermostat
c/h switch on control box is set for 24 hr and thermo is set at max
no c/h
it worked when the boiler was heating water
very cofusing
so its got live to it n0 1
so i would check n0 3 connection.
or remove 1-3 join them together with a choc bloc if boiler fires you know
everthing else is working.
