Drayton Tempus 3 - can't turn heating off
17 Sep 2014
Hi all
Living in a rented house no manual for the heating system
It is a Tempus Three
Despite thinking I have no heating selected it is belting out heat several times a day
Can anyone please point me in the direction of a manual ?
Or tell me how to turn the heating off totally without affecting the water
I am at my wits end
Thank you in advance :cry:
I would like to re programme or adjust settings myself it is not convenient for me to wait in for an engineer
I have searched google anyone have a link to a manual please
My point is, that if you have turned the thermostat down, then the heating should be off.
If you can't work out how to set up the timer without the manual you are doubly screwed.
You'll have to wait for an engineer. What is more inconvenient?
The fault is not necessarily in the Tempus programmer.
Have you got a hot water cylinder, and do the radiators warm up when the cylinder is being heated, e.g. after you have been running the hot taps?
Do the upstairs radiators get warmer than the downstairs ones?
To save wasting heat and money, turn the radiator knobs down to shut them off.
Hi I have a hot water cylinder, the radiators warm up when the water is being heated
I had already turned off the upstairs so don't know if they would of got hotter than down stairs
But downstairs get stupidly hot
Beyond my ability to fix I have no tools
Will have to ring landlord after all :-(
Hi all
Got emailed a 10 page document
Can't open it on my phone but will unzip it when I get home
As people say they are hard to get can I send it to admin somehow to share ?
As others have said, if the thermostat is set to 0, then your heating should not being coming on.
You should be able to turn your heating off on the Tempus Three with the second button from the right. See this post for a picture: http://www.diynot.com/forums/plumbi...l-cm927-wireless-thermostat-to-system.351751/
It sounds like a motorized value is stuck open letting water through to the heating circuit and the radiators.
Also worth checking that the motorized valve has not been accidentally overridden with the manual override lever.[/url]
