Drayton Tempus 7 problem - HELP needed!!
18 Jun 2006
London
Hi, The display on my Tempus 7 programmer is on the wonk and we don't have any hot water (or heating, not that we need it at the moment!)
The 'current time' display has gone completely and the settings will not register. The buttons on the left and right side (water/heating) do not work either. The sliding button on the bottom does not do anything. If I replace it, will my boiler work again?
Any help will be much appreciated, damn, I need a shower!
9 Sep 2005
Sussex
Perhaps there is no power to the timeclock (some clocks loose the display even with battery backup). There should be a fused switchplate or plug for the heating system.
18 Jun 2006
London
The times at the bottom of the display i.e.on/off times are there, but they will not change. They change when the slider is moved, but they cannot be altered??
The black dot at either side for 'on, boost' etc. is not there, nor is the 'current time'
TIA
24 Jul 2003
London
SOunds broke then. Try turning off at the mains for a while, it might feel better when it wakes up. I've still got some of those, new old stock, if you want another email me (see profile).
18 Jun 2006
London
Hi doitall
I do still have the userguide and tried everything, but it still won't work.
On the link you posted, where it has 12:35PM and the 2 black dots, they have 'disappeared' and aren't there at all now.
8 Jan 2005
Bath
Press select and time+ at the same time and it resets the programmer to factory settings
Otherwise its duff, and you want a new one.
20 Aug 2003
Cardiff
I have an old model Tempus 7 (about 10 years old) and the LCD display is almost gone. When I buy the new model, will it fit on the old backplate so I don't have to do any wiring?
