I've almost completed the porcelain tiles in the bathroom.
The wall where the shower screen needs to be fitted is a stud wall. Before fitting tile backer boards I inserted timber noggins corresponding to where I anticipated I'd need to screw the shower screen vertical hinge and marked the adjacent door frame with the noggin centres.
Turns out the position of two of the three studs coincide with tiles joints. I anticipate that the shower screen will require 6mm or 8mm holes to be drilled.
Is it problematic drilling the grout joints between porcelain tiles or does it make the task easier.
At my disposal I have 2 x 8mm wax filled diamond tipped bits. 1 x 4mm and 1 x 6mm carbide tipped multipurpose drill bits and various sizes of standard masonry bits.
