Drilling through engineered brick
1 Apr 2004
I want to get a waste pipe for a sink through an external wall - the problem is the outer brick is old engineered brick and doesn't won't give in without a fight. I broke a standard masonry drill bit just trying to drill a hole for a screw in one of these!
Can anyone tell me if I can drill through this brick easily? Do I need a special drill?
I'm tempted to remove a whole brick, cut it to size and then replace it. Is this a good idea?
Thanks in advance for your help...
R1
if you intend to drill in future invest in a cheap sds drill, the ends of the bits move in and out of the chuck
the drill bits are quite dear but they go through concrete like butter with hardly any wear to the bit. your only problem might be the cost of a 50mm dia drill bit so the previous reply might still be your best bet but a sds drill is essential fir diys.
Make sure you check which type of SDS drill you have, you can get SDS or SDS Plus. Also don't get a cheap bit, I have seen cheap bits melt trying to get through concrete....and last but not least, don't do what most 'rag heads' do and drill from the inside, you will only blow off the face of the bricks on the outside, always drill from the outside.
Diamond drill cutters are very good and neat and tidy, but used by inexperienced people...I've seen more wrists strained and broken though people not instructed how to use them, take great care!!
