Dry verge mortar mix
27 Jul 2006
Can anyone confirm what ratio i should use for re-pointing the dry verge please ?
There are a good few chunks of the original that are missing so am planning to knock it all out and re-point the lot
I've seen 4:1 and 3:1 mentioned so wondered what peoples thoughts were here
Also, should i primer it on the underside tile edge and roof board with either neat or diluted PVA to help adhesion ?
Thanks in advance
You can’t re-point a dry verge, they are plastic.
3 building 1 sharp 1 cement was the last one I did, I did a scratch coat first shoved in then gave it a key, then top coated it next day, making sure I compacted/tooled it well when it dried a bit.
I’ve also used just plastering sand and cement and it was solid as a rock and still is.
The real proper way is to take the tiles off and bed them down into the wet mix tho.
Fit dry verge, it’s maintenance free lol. Amazed at how properties have upvc doors windows fascia and soffit yet wet verge and ridge
...but my pointing is falling out and obviously near end of its life so what I would be securing the plastics caps to ?
The instructions I have seen is to simply use mortar screws
Personally the dry verge stuff looks ugly but we will live with it if we have to but as I say, if the mortar is falling out in some places now the whole run will at some stage
23vc actually suggested a 3:1:1 mix which is 4 parts sand so would be weaker than 3:1 surely
You fix the dry verge to the batten ends which are behind the existing mortar, using metal clips. Google installation instructions for klober dry verge
Yes the ratio I suggested is 4:1.
