Dual fuel cooker running on 13A plug for 16 years. Would similar replacement be OK?
3 Mar 2013
London
Hi All,
I’ve had a Hotpoint HUD61P dual-fuel cooker (gas hob, two electric ovens) for around 16 years, connected via a standard 13A three-pin plug into a dedicated socket behind it, installed this way by the original builders ~2010. There’s also a red cooker isolation switch on the wall.
Despite the original cooker being rated at approximately 4.8kW, it’s worked fine without any apparent electrical issues throughout that time. We only use one oven.
Since it’s now discontinued, I’m considering replacing it with a Hotpoint dual fuel HDD6GDC2WX, rated slightly lower at 4.4kW.
My question is, given that the existing cooker has worked perfectly well on this setup for 16 years, could the replacement realistically work just as well, particularly as we’d continue using only one oven? Or is there a significant difference I’m overlooking?
Appreciate that the manufacturer specifies hardwiring, but interested in the practical electrical reasoning and experiences of electricians who’ve encountered similar setups.
Thanks in advance
Is the socket fed by the cooker switch or part of a ring or radial socket
The cooker plug socket (behind cooker) is definitely fed by the cooker switch above worktop, but not 100% if just the cooker in isolation all the way from the consumer unit, or any other switches on the ring as well. (If i've understood the question correctly)
Basic idea is, used for a short time, a BS 1363 socket can supply 3 kW, for a long time this is reduced to 2 kW, mainly as the socket now has insulation on the live pins, so it can't transmit as much heat to the socket, and also typically now white, not brown so again can dissipate less heat, however with the plug in forced air from an oven, it can likely dissipate a bit more heat, but that does not mean one can exceed the 3 kW limit.
It would have been drawing 19 amps, which is not really an option.
