Earth problems
22 Apr 2008
Leicester
Hope you are all well, can you please help I have to earth the mains cold, and hot from the cylinder but I have removed some copper and used plastic, so the sink and pipes are no longer earthed, the nearest earthed appliance is the cooker so I was going to connect to the 15 mm gas supply is this ok, but also they might have now made the gas and water incoming mains to plastic if this might be the case what do I earth to, I am at a loss lol.
Thanks for any help
Main earth bonding in 10mm to the gas pipe and water pipe (less than 600mm from gas meter and main water cock) + rcd protection removes the need to supplementary bond.
When the above isn't in situ supplementary bonding of extranous metal work / pipes is not required for a kitchen sink- it applies (mostly) to bathroom rads and taps.
Check the DIYnot wiki for more details.
Chri5, thanks for the quick response, i would say that the oven supply pipe is about 5 meters away from the meter so i guess i am stuffed lol
i have read on some web pages that as you say kitchen sink does not require earthing, is this beacuse its earthed on the incoming main, if this is the case i have broken that connection as i have used hep20 or do i just not need to earth the sink at all, im sorry for been thick
You don't need to 'earth' any of what you're talking about.
All you need to do is BOND the incoming water and gas mains. Bond them as they enter the property with 10mm^2 back to the Main Earth Terminal.
Thank you for the information and just to clarify that even thu i have a copper main then changed to plastic and then back to copper i do not need to earth the pipe or the sink as this is no longer a requirment, and it does not matter that there will be no earth at all for the sink and pipes,
Thankyou i will sleep with out the worry now
You should read this excellent book that's on Amazon. It's called "An Illustrated Expl..." :eek: :LOL:
YOU DON'T EARTH ANY OF THAT. EVER. THE ONLY THINGS THAT ARE EARTHED ARE ELECTRICAL APPLIANCES ETC.
You need to read up on bonding - views differ on maintaining continuity through mixed metal/plastic installations. :confused:
ok guys i know i was just worried about it, i need to read up more but thanks for your help
