Hi. After recently paying a little attention to my electrics at home and spending time writing a list of what fuse protects what in the house i have become concerned the house is not connected to earth as it should.
I know the house was at some point connected via a TT arrangement due to a spike and connection box with a cut earth cable outside the front door.
At some point the earth cable was cut (dont know when or by whom - i brought the house 2 years ago and the previous owner had no recolection of when the electrical installation was last modified)
The current arrangement, for which i will post a couple of pictures this evening, consists of a fuse carrier marked 100A (not likely) with live and neutral connecting to a 80A 100mA RCD (wylex) then continuing to the meter and radio switch arrangement for economy 7, and then to the two relevant consumer units complete with old wireable fuses.
Each CU has an earth connection to the earth block, size 4mm. There is then what looks like a 6mm which bonds the pipework in the Kitchen/Bathroom (only pipework in the house) and i would say has been installed in the last 5-10 years at most.
There is also what can only be the remanance of the old TT connection on the earth block also but this is not connected to anything else other than the earth block.
Could it be possible that the old TT connection was removed and replaced with an undersized earth bond to the pipework - the cable is bonded pretty close ie within about 1.5M of where the water supply comes into the house.
Many thanks in advance.
Anthony
Anthony
