Editing DVD / .ts videos
26 Apr 2023
I've got some files that were recorded onto a memory card, which I would like to put on a DVD.
I've transferred the filed to my PC, but now want to edit/trim the video before hopefully burning them onto a DVD.
So far I've tried avidemux which saves the video as .mkv that I am not familiar with and Microsoft Clipchamp which exports the video as .mp4 and will take ages based on the on I tried.
Does anyone have any suggestions for a simple, free editing software that I can use.
Thanks.
I've recently started using Shotcut...
First impressions are very good, it's powerful and easy to use.
I've also been impressed by being able to experiment with effects in real-time.
I'm afraid I haven't played with DVD authoring, and I know this isn't the simple software you were searching for, but it may be worth a look?
Edit:
Just remembered, Avidemux allows quick edits of MPEG-2 streams (.ts), because it can cut off chunks of video, without having to re-encode the whole lot.
Encoding the video with Shotcut, will possibly take as long as it would with Clipchamp.
Thanks for your suggestion. It is definitely worth a look... I will just have to see how long the encoding takes.
I don't necessarily need simple software, but I want something easy to use to do what I see as a quite simple edit ( i.e. I won't be using the bells and whistles, so it doesn't matter if they are there or not).
MKV is one of the most common video files and produces high definition video with a small file size.
Home burned dvd can become unreadable after a few years.
Make them MKV files and install VLC on your PC, also put the installer on the disk too.
Being able to find a portable version for on the disk would be better though.
On 2nd thoughts, use the kdenlive standalone version on the disk.
This way, your able to play it on any system that may not have the correct player installed.
I had a bunch of .ts files from an old camcorder project and wanted to clean them up before burning them to DVD too. I tried a few editors but always ran into slow export times or weird file formats. Editing MKV files doesn’t bother me now since a lot of editors support it, but back then I just wanted something that wouldn’t need a full re-encode every time I trimmed a bit off. For basic edits and format compatibility, sometimes I use https://www.movavi.com/learning-portal/mkv-editors.html since it recognizes MKV and other strange files straight away. Worth a look if you’re tired of messing with conversions and want something easy to handle these edits.
