I'm building a log cabin office (about 5mx3.5m) and I'm going to insulate the roof with 50mm insulation board. The insulation is made by Mannok but is basically the same as Kingspan, foil-backed on both sides. The plan is to get the roof deck on first (pine tongue and groove boards), frame the outside edges of the roof deck with 2x2, glue the insulation down inside the frame, then glue a single sheet of EDPM on top of the insulation and frame, then finally fix the EDPM to the underneath of the soffits.
Any idea what sort of adhesive I should be using? PVA is cheap and works really well on almost anything, a lot of EDPM sites talk about contact adhesive and of course there's a plethora of "specialised" EDPM adhesives that are as expensive as the EDPM itself and might just be PVA or contact adhesive for all I know.
Any opinions on this? Has anyone done this before?
